Datalog F30 N55 PWG BM3 Stage 2 low boost on high rpm
5TOLE
Hello,
Does anyone have idea why I can't have more boost at high RPM? I have talked with people at Bootmod3 and they said it's limitation of PWG stock turbo. Is it true? Why is my WGDC at 60% if I miss so much boost at high end? Should be more to fully closed (100%) if I'm not mistaken? Beside that can anyone please check overall health of my log, is there anything more I can do before going on turbo upgrade.
LOG link (my boost is shown as bar, not psi since I'm in Europe). I miss approximately 0.5 bar or 6 psi on high end.
Car spec
• BMW F30 335i xDrive 2012 PWG Bootmod3 Stage 2
• N55 Engine
• 8-speed automatic transmission
Mods
• 200-cel Sport cat Downpipe
• NGK 97506 SILZKBR8D8S Laser Iridium Plug
• GFB DV+ upgrade
• FMIC Intercooler
• FTP Chargepipe
• HPFP HDP6 B58TU (Supra)
• Bootmod3 Stage 2 engine flash
• Bootmod3 8-speed transmission flash
• MST Intake system (BW-MK3351)
• MST Turbo Inlet Pipe (BW-MK3352V2)
Dyno numbers
• FBO Stage 2 - 330 hp
• Stock - 275 hp
Dragy GPS numbers
• 100-200 kmh (60-130mph) is 11.13 sec (xDrive)
• 1/4 mile 12.67 sec (-1.54% Slope). I need to measure again.
Thanks
CNM135i
60
18
M135i PWG
Correct. 10-11psi is all you will get from stock PWG. Also answered you at Bimmerpost...
5TOLE
Thanks again m8, you are only person who is willing to answer. I appreciate that.
@CNM135i
I made this post first, before Bimmerpost. When I saw this is dead place I went there to ask.
4,331
@CNM135i
It's easier to get your logs looked at here if you use the built in datalog feature and embed it in the post. If you are using MHD, they are integrated into this site so you just press the button and the logs appear here. Then you copy in the BB code into this thread.
ms_logging
even with physicaly closed wastegate got arround 11-12 psi not more. )near redline. runing out of eficiency. to small one )
Reactions: AK-335
all4bspinnin
178
98
135i TT
With proper tuning you'll be able to hold a bit more to redline on this setup. I wouldnt say 15 psi but you may be able to get another 2 psi out of it by redline.
