E92 Chevy Bolt Pattern
mcleansc
I'm based in the UK and managed to score a set of Weld Draglites for an amazing price. They are Chevy Bolt Pattern which is not far off our bolt pattern.
Before I get studs to fit will these work on the E92 platform or is the small difference in the bolt pattern too dodgy to run?
TIA.
DCook
They'll work with no problem. Many did it years ago and still do.
Imagine the mechanical pencil, the thickness of the lead, is the difference. Its marginal. Some guys will argue it, but id just send it.
Also are they shank or conical? I know shank style is very snugg fit and less forgiving over conical.
tisdrew
You'll also need to ensure the hub bore lines up. You might have to get hubcentric rings to buffer the difference assuming the bore size on the wheel is just slightly too large for your actual hub.
mcleansc
Thanks for the replies, good to know they can work. Yeah tisdrew I'll get some custom spigot rings made up so they fit snuggly. Now it's wether to go steel or titanium studs and nuts
Top
