DIY: CIC auxiliary video input
houtan
628
310
135i N55 DCT; PS2
Slowly working my way to do this. Got the tv option coded.
Quick question, is the quad lock behind the head unit or the navigation screen?
houtan
628
310
135i N55 DCT; PS2
Do you guys think there is a way to run audio through the oe connector as well?
4,332
Nope, just use the Aux line. I mean, its possible, but I can only imagine it being a total pain in the ass, but I haven't really thought about it too much.
Evgeni
BMW 325d Lci
Hello
I have a shielded cable problem. All the cables I found are with 2 wires inside and not with 3. Can be done with a 2-wire cable or should be required with 3.
Sorry for my English i use google translate.
2,251
805
You have video + and -
Shield is required for noise suppression you can go without.
If you have multimedia snap in in the console then use that input. Video and sound available
90luke90
E91 LCI 330d xDrive
Hi guys,
will this method work on every CIC?
I have an old one from late 2008 with 2012 firmware update, no combox, no reverse cam, no nightview, no dvd changer or TV tuner. Will the Video Input be open after I code the FA?
Best regards from germany
Evgeni
BMW 325d Lci
Yes it work, my navigation is from 2008 I had to buy these connectors:
61138387206 white
61138384550 black
61130005197 2x pins
Evgeni
BMW 325d Lci
I bought cheap mirroring dongle with av output and cast my phone to navigation display. I use it to watch live data from the car and track the regeneration of the DPF filter.
ZvUosdRvh4Se1nuiLU70DfwG54UuEQjWBC-Il5sJvL0c8eo4PboT-hZQItzDaaZKIoWGLbGZcFf_ghvk7Li3OF55s3tfxv4Yw8zzWUnartNeoCLNoBAxmuyEnriNGBZa8veSaTXUnVx2mmtoMx6Pv6GTYx4RosKfG788QSLa-jCKAXx24fJm_u3MyjLmIwkn-yonmAYdMIN5PjRV5P01j8Letgofkx0bZKeBxGgcwUDhhNR0_MYe4hAxcOGhCiHOdH6WF_n3J2vPJpHF1GUo5Hf8e0r-Cg4i0fJW4yu4IstybbORqnBhUEk9mntUBhOEwzvjWVFwElZhNNHO-gXB5hAUwbo41ynAidx22VVttAmpojeXAsdVTRwRtV7BsP1HmQReIVDAv_GTlBAvFHivAXtghjjCt4ZrwJH6bC0SmaRQzG2G4YmB4NG8VP2ZxClm63MEcy_umx0TwCzGDtkztNgng134px8xxuzlWaStx6aRQ6oPTNyEzNYeOnS5iYXnqIKq0vrXJTS7-USEAS3Mjp7gI_eWh7JOsSHC4smWTbmI0opwEjQi3Sst-wGmurSpK0mb4wFdKmUFf5ufR7ZENu8AcslZdSvKybIH_NA=w1470-h828-no
lrdJLLKZTwjLYxW_8ChNpC82YJR_AouwvEY3_v68YV7aT_Rg32itVVM5clrHJsJ69CN3oAPV2ROYKd3EgXrWZ9tNVkjn3z-a9NwX3FRdBogBcM7leAb-Ir6FbUY3Aw61iYX6zTu39_1DP5e-JvdasqDJI93U3gIkNlOOkYa1hW5LGRCEau9tTDS6CjqUavW0oDv5ngynZ-KfEwnzJMXWIoAo-SUuXIYHMltqctTveAOFuzNr9uk-6dLDDJ8nzM8htJK43mYhRdQZu9jGGmqs6Rp1RPJRMOfwMkIo51ik5VLxDpeMZl6NyvyfGpjjpeIwfF3MLlGoXKr3ZdYT-mfOsb8KtL8KbYw4VBEUFYM8XIBqBKPa9bnKgK54YuFtVtJf_XpbK7Ro6n96hPGCov3HiXno0aF470EfLInbzlOKyeTMdRQS0nG4plRxIg0bGQDoWjm8FILUbZ-OFt7PZU66-Ojwew5I-J53OVKJK0Wc76-Ju1TPiRIN022P808Enpr_hlGggwPu-0JH_4x28XLxKdGTOOhdHqiYe-VjAVpxvD5SJNPb8jgVJkMuW-_-wgV5oHVPn4wp39qVlXQKyuEKm-9oWu0-unxQr3e-O9k=w1470-h828-no
_kZEHrYwu1f2O5ZOcwNoVm8Y5M0qR8B9xOb_BYw4VyWtBXqYqVMott1xc9yGFr52lPSiQbkZwUu1RyNjO0SDqvYpejm_vU2Ah9XzLxeC2BFB-yHFlezyAYtJVFoy2GLQA71wxZYC4Xca3wPAsm-3j4a7Mg9ThQHD1ZN9sHIkZ4VPUd92O-HVRmHusfiEcqmnw0fspLSVaiZApZ-c8B4M5W0dw9dbUUhGjW7k7XzJtPMHugtn--3ATxgnxVOii1pF53tJx6l8h85q8ld7fP630p6r257WIyVHCDRyugwbz61c2KG9TEhGsPcOQ6K0hKeJobddGxtuFle7iIIJ3ebtEhLYYV8RpitUZNNPmM6wOmapHEY2EjQQJbuXSsJ9LMpnfkEk2DDzaXHGAmHVLZXPEm3hF0IH3uu4cmy5LmafnZodGs0SP8ZO8ZW709GtpwEVBASpMLKcnSn_MHW2YB9qLihaOCyy9vqrtNQ-9T9LOcSrx4tjZfs5-iYJzMH5fXbPb_9yE-cvQRsTjFv84erz67MFps3PEwsXnhNfZESRiWw0Vl6peAzVOmhj3azNFqiwVAgwZRYUtGjs44kkzrudFjoN39ZFtDWdp47jheA=w1470-h828-no
I have a problem with the resolution cut off my screen a little.
xradeon
BMW 135i 2013 MT
Hi! Thanks for the tutorial. I have already completed it and now I can display my iPhone screen on the CIC. The only that I'm missing too is a way to change from 4:3 to 16:9.. Has anyone found a way to do it? Thanks!
dam
E70 LCI
Thanks for the tutorial - It's working. I have already completed it and now I can display movie or DVB-T on my CIC screen.
One problem is - How to change screen format from 4:3 to 16:9. xradeon found a way to do it, but he no reply. :(
can anyone to help ?
Evgeni
BMW 325d Lci
As far as I know you can not change screen format. And one more thing you do not need to add vo601 in CAS and NFRM. Just code cic:
TVM_VARIANTEN
vm_l4_most_fkat
TV = wert_21
And the TV function will be available in the Idrive menu.
dam
E70 LCI
TVM_VARIANTEN
vm_l4_most_fkat
TV = wert_21
Really $601 is not need ? I check coding all options in my CIC (cic.c1a) and all working OK.I have only 4:3 format, but xradeon do it 16:9 format. Question is - HOW ? Have you seen this post? (xradeon post and photo).
https://bmw.spoolstreet.com/threads/cic-aux-video.754/page-2#post-39817
Evgeni
BMW 325d Lci
Yes not need it. The first time I coded, I had added 601 but then read in a Romanian forum that you do not need it. Then I removed 601 and everything worked. I use the tv function to cast my phone screen to CIC display and when I turn the phone to the side the picture becomes 16:9.
dam
E70 LCI
OK. THX I try removed $601. Do you have two black stripes on the sides of the picture? What does your screen picture look like here (with black stripes) ?
or look like here (no black stripes) ?
dam
E70 LCI
Sl0oCrHKbh5ex_RLZ6BJyTWe4cygqyE_E_n5bsh7pG05_a0BBez1_thOBWkgb174_nrb9XQjF-NRpRnzXZne8Vq7xdYO-IaRJxE9DHhpPT-jdG2HrSZPXlw1ozPVa03AYFlhEZJWpOnch95YzzrWhpIwVxQZ1402Mc5LIMX9YD8wkEJQBIjhGc60eSpoaz1LoQ4L01G7LCIHHcwqUhOdKsFPXDFT8eNDi2d-tILEVX0W8xIrE27g36gDP-U1H5LmNxy_9JBV-x95G4Ha-ZkicI0zYiL5GzatgS-nXDAaQCmPjYyjSa_m7pi7RNKeBfNgKObuZqZ8efix0-PqA_tt2JP12FHVc5Q8QI3rn06Boi-ivZllr5VhpVYybFzocc-BY8okx9Ot1y9URzeAc2Loc7diLyVgZhYsn5wV9_CSdjFMybaDYNJDg_LhTWphN76avBFSLN8AKfG1ITsQUn0s6xZ1clnVgLD3Kzfvz_9v3xOiF-KomHAGdY0-1OQstIPwrYnv4rUkd5UckT9ik4FUNvpOq0SsgS2BUxWGL500myWD-TDba9iD2lbgFQwLqiyhAzsYen-E8xCFjeaoPenEpLpTYXH1mGGrwCne-ec=w1260-h709-no
Hmmm i have black bars. Now i want 16:9
Hmmm, I think this is not a real 16:9 format. Your image on the screen was cropped. :(
In the post "xradeon" the picture shows that the image on CIC screen has larger proportions and hides behind the screen divider. I do not see the black bars on the sides of the screen (maybe little on the left side). How did he do it ?
Does anyone have a description of all functions from the CIC module that can be encoded?
2,251
805
I think that the DVB input has a max ratio of 16:9. Some of the options that people are using aren’t using this input but rather hijacking the LVDS straight into the screen and they can use different ratios..... I think...
