Cold start overdriven hpfp rattle fix needed
AzNdevil
567
270
Hong Kong
So @V8bait modified my tune and she started like a dream and no more rattle with cold start deleted .
She fired up perfectly first go without any stumbles or hesitation.
Thanks AzNdevil you are a bloody legend.
glad it worked out ;)
attached here for ikm0s peeps
Don't trust the Fuel Pressure Target (Homo-Cold)
I can't make sense of it and I didn't look into it further since you guys managed to get the pump to shut up after playing with the Coolant Temp Thresholds....
  • IKM0S (Standard Units)-AzNdevil.xdf
Anyone can help me out need the Ikmos VCV tables including current request to pwm request, flow to current request, max current, and the respective breakpoints
AzNdevil
567
270
Hong Kong
i think these are available on vtt's site to support shotgun tuning
lmk otherwise...i can look into them for you
TheFixer
493
352
Tennessee
2008 535i
The hpfp can be noisy? I have a lot of rattle noise on start up. After reading this thread I wonder if my hpfp is making all the noise i am hearing on start up. I thought i have a noisy air pump.
4,332
If its overdriven in anyway way it will be noisy as it's part of cold start which has to be turned off
The hpfp chatter fix can eliminate 90% of it. The problem is there is an initial startup that causes it to chatter as well and I believe someone said the only way to eliminate that would be to play around with the voltages which at the time nobody felt like doing.
586
i seem not find information about how to fix it. Anyone care to explain what needs to be done?
Traf
348
203
135i
In which tune?
There are multiple tables available to reduce the current applied to the VCV during startup, and the time frame during which this current is applied.
Everything is available here on SS.
586
I have all the tables. I was asking for advice how to work on these tables as i have no experience. I did not find any info on tuning direction.
Traf
348
203
135i
Reduce the time during which the startup current is applied for example ?
