Clock spring re-install
LavosB
13
Hey guys! Anyone with experience on how to re-install this ?? I was trying to install new steering wheel and this came off ... I’m a noob so please help ! 😅
  • Wow
Reactions: derekgates
derekgates
740
375
NW FL
derekgates.us
2011 335is
Ouch. You can ... certainly rewind the clock spring... but I can't guarantee it will be 100% back to normal.
The ribbon that came out has traces that is read by 'copper fingers'. The pulses tell the car where the wheel is situated. I do not know how sensitive the computer will be to those changes.
I was not correct, it just returns the wheel back to position and powers the airbag. Shouldn't be too bad to rewind it, but I haven't done it before.
Can you source a used one? I found them for as low as $24 on Ebay: https://www.ebay.com/sch/i.html?_from=R40&_nkw=bmw+e90+clock+spring&_sacat=0&_sop=15
4,332
I did this once. I installed the steering wheel and didn't secure it and I pulled back on the steering wheel and ripped it off, spilling the clockspring guts.
You can take it off and rewind it, but the chances of you having it 100% again is not certain like Derek has stated. Unless you're on a budget, just buy a new one for peace of mind.
LavosB
13
Thanks a lot man big help! I’ll probably buy a new one thanks also for the source, I’ll probably buy it there 🙏🏻
LavosB
13
Yes for sure I’m probably buying a new one I don’t want to risk it, thank you for the reply 🙏🏻 Big help!
TheFixer
493
352
Tennessee
2008 535i
Wow. I've had my steering wheel off twice. Didn't know that could happen. Good luck with that. Sorry it happened.
