CES Motorsports teases Production N54 Twin Scroll turbo kit
Jewgo
65
28
1r
Torgus,
I could see a water cooled turbos being useful for those deep in the south like myself that can see 110+ degree summer days. Also, our cars are already setup for water cooled turbos, why not take advantage of it?
Reactions: GreyNBlueE92
2,194
Torgus,
Unless I am mistaken your external outside air temp has nothing to do with wanting a water cooled turbo. The water cooling around the bearing helps during all operating conditions but gives its greatest benefits during hot shutdowns. The water will “thermal siphon” and continue to pull heat out of the turbocharger even after the engine has been shut down and the water pump is no longer pumping. This will keep the exhaust heat stored in the turbine housing from coking the oil in the turbocharger and potentially damaging the bearing and turbine-side oil seal. They also make 'turbo timers' which will continue to circulate the water after you turn off the car for a set time.
If you run your car with a non water cooled turbo hard, let it idle a bit before shutting it off to prevent coking. That is all you need to do.
There is no reason to not take advantage of it other than the extra cost of the turbo. Most top mounts who wants oil & water cooled will be look at Garrett so add roughly $500 on to the price of the precision turbo roughly $2500 depending on model + lines etc.
Reactions: MDORPHN
MDORPHN
196
162
BMW 1M
Agree with Torgus. The difference in ambient temp between a hot and cool climate is insignificant relative to the turbo-produced heat. It will, ,however, have a greater effect on IATs and coolant temps.
Neil
4,331
4,331
@JohnCES
Guess it's about that time...
770whp/725wtq... 520wtq@18psi 3500rpm
CES Motorsport N54 single turbo kit
Garrett Gen2 GTX3582R Turbo/Steedspeed twinscroll turbo manifold/Stock n54 motor/E90 fuel/dual lpfp/EOS intake manifold w/PI
Out Gen2 kit will easily see 800+whp on built motors. Didn't want to push the stock motor too far . Pre-orders starting soon with info and pricing on spoolstreet.com
#335 #335i #n54 #racecar #bmwlove #carswithoutlimits #carsofinstagram #tuning #custom #bmwcars #boosted #power #turbo #turbocharged #instacars #bimmer #streetcar #passion #performance #bimmernation #bmwlove #bimmers #single #life #whoneedstwins #qc
