"Carbon fiber" replacement door pulls
1,267
771
After replacing one door pull already and having it, as well as the other 2 begin to turn to sticky goo, I decided to give some carbon fiber style door pulls a try. These are straight from China, no branding, but they fit fine and even if they don't look like real carbon fiber up close, they are good enough, and they aren't sticky so that's a plus!
Install was cake - drill out the OEM ones, install these with the provided screws and reassemble. It is both sides of the pull as well which is nice.
For under $80, this was a good mod. I probably spent close to that for one OEM replacement pull before.
derekgates
740
375
NW FL
derekgates.us
2011 335is
Looks good!
I admire the 4 door versions of these cars. I deal with the monstrous 2 doors and can't fathom people sitting in the rear of my car. I get surprised seeing a usable rear seat! :D
derekgates
740
375
NW FL
derekgates.us
2011 335is
Freaking funny. :D
In all seriousness...
- Try to level the photo the best you can... you can enable 'on screen lines' to help with orienting to horizon.
- Keep lens clean, it looks like there is some smearing.
- Don't shoot directly into light or an area with more light than the focal point. Dynamic range is very limited on phones so try to keep the ratio reduced (and prevent destruction of shadows).
- Be sure to tell the camera app what you want to focus on. Usually by tapping on subject. It should focus and adjust exposure for the desired point. (you should be able to adjust exposure by holding and dragging up/down depending on app)
3,606
Well you sure as hell know more about turbos than cameras! :tearsofjoy: :tearsofjoy: :tearsofjoy:
KClemente
289
147
E90 335i
Does that door pull clip on like oem? My inners are still good thankfully but the outers have that annoying "lemme dig my fingernails into it" look
