Currently trying to track down a problem on warm starts. The car will fire up just fine on a cold start but will fire up and immediately die when the car is started whenever it is warm. A second sometimes third start up will usually do the trick or I can keep the car alive the first time by feathering the throttle for a couple seconds; it will idle/drive as it should after it catches itself. It also doesn't trigger a code at all.
Could my injectors be leaking causing it to flood? I recently replaced all of the seals/de-couplers during my VC replacement and I am running PI. Also just replaced plugs, coils and both VANOS solenoids. Smoke tested through my TB BOV adapter port and it doesn't show any signs of a vacuum leak.
