I have finally received the boots and coils from RockAuto/FCP and there is some bad news
There are reports that BMW has changed the design of the flange on the B58 coils to be longer and skinnier; there are reports that this is without a revision or change in part number from BMW. Unfortunately the rubber boots listed above do
not fit the coils. I bought brand new OEM Coils that specify Eldor
and "BMW" on the top.
You can source older coils with the older flange used but if you would ever need to replace a coil you would be screwed.
Also this rubber boot is beyond a tight fit for the B58 plugs. Whereas the B58 coil fits snug on B58 plugs, the above mentioned boot is tight as can be. This was the furthest I managed to wedge it on before I became uncomfortable with how much effort I was exerting to fit the coil
Also the provided spring? Didn't look like it would work. The boot "passage" is very skinny and looks like it would barely fit the skinny spring, let alone the B58 Resistor
Unfortunately it means I have to return these and take a gamble on the Nexsys style boots I posted earlier. Hopefully they will be a better fit. To add insult to injury, FCP sent me "Champion" branded Spark Plugs when I paid $10 a plug extra for OEM Genuine BMW plugs. Hopefully they won't make a fuss on the return but considering their recent change in return/warranty policy, I have a feeling I will be in for some headache.
Today has not been the best day
EDIT
Here are some more pictures of the new coils I received from FCP
It would make sense why BMW did not change part numbers despite the difference in parts, since the coil and boot are sold together and have the same physical dimensions together as the older coils. I don't think BMW ever had any intentions for anyone to separate them and notice that there is a difference. I'd like to believe that this was just a simple revision but it isn't completely unheard of for BMW to modify their parts just to spite owners of older models or people looking to "futurefit" their older models with new tech/parts
So that's $15 down the drain in shipping charges and if the "Nexsys" style SPP170E boots don't work out that's another $15 gone in returns. At that point it would have just been easier and just as cost effective to buy the boots directly from Nexsys ($60 with their updated springs) but I guess my monetary loss is your informational gain. You
will be able to find out which boots/springs fit and you
will like it!
YES, YOU! Reading the first page of this topic! You better get your ass over here and read this post because it's important and I'm wasting good money figuring this out so you won't have to!
![Squinting face with tongue :stuck_out_tongue_closed_eyes: 😝](https://cdn.jsdelivr.net/joypixels/assets/6.6/png/unicode/64/1f61d.png)
