B58/b48 Genuine Bosch Direct Injectors and Rental Install Tools
trevorjelam
Jul 18, 2021
13
OEM Replacement Unit: Bosch Gasoline/Petrol Direct Injectors. Buy Your Injectors Here!
We are starting to see Injector failure become more common as our B58 Platform Ages and is Pushed Further With Ethanol Blends Etc. These Failures in worst case scenario can cause Catastrophic Engine Failure If Not Serviced/Replaced in time.
This is why we are offering Injectors and storing In bulk in the US and rental specialty tools to Provide Quick turn around and shipping, at an affordable price for our valued customers.
Rent your Removal/Install Tool Here
Rent your Seal Removal/Install Tool Here
View Install Guide Here
Bosch Number:
  • 0 261 500 541
  • 0 261 500 542
  • 0 261 500 539
  • 0 261 500 140
Alternative BMW/Mini Number:
  • 13 53 8 625 396
  • 8625396
Bulk orders can be an option as well if you are a Retailer wanting to offer injectors. Email me at [email protected] for inquiries.
Find it cheaper? Message us with proof of supply/cost and we will do our best to match it.
986
This is interesting, Started looking into B58 Failures after yours sadly went boom @trevorjelam. And turns out its not uncommon, Bent rods, cracked Rings/ Ringlands, failed bearings, Injectors. All the B58 problems just don't seem commonly talked about. I see people chanting B58 over N54 but i don't see the hype.
Also Trevor Congrats on starting on your built motor adventure, that's going to be one fast machine. Curious if your building the trans, or doing any other drivetrain modifications.
trevorjelam
Jul 18, 2021
13
To be fair, my car was being pushed pretty hard for a stock block. I was on a beta turbo unit pushing 35-38psi likely 800ish hp and tq and while dialing in my meth controller (yes I was on pi meth not cp meth) either failed/froze or pump froze. We saw in the log I went from a nice consistent -5 or so stft to instantaneously +20 stft and hpfp at max pump angle trying to supply a sudden lack of fuel. This leaned out the motor and ringland piston #1 shattered and melted. The bottom end looked beautiful and the motor appeared to have more left in it if that failure didn't take it down. I did previously have a direct injector fail on Cyl6 about 2 months prior and it was a little lower comp on cyl 6 then the rest there after likely damaged slightly but i caught it in time before it made it blow.
Pictures attached is the failed ringland and condition of stock Rod bearings pulled at 56k miles and about 25k of those miles being different setups ranging from 500-800ish hp.
SlowE93
1,655
Just a plane ticket away !
E93
How did DI fail on cyl 6 ? Don't think it stayed open so...what happened there ?
trevorjelam
Jul 18, 2021
13
6 seemed to have gunked up either be it Ethanol Gunk or Carbon build up. It clogged just enough to were it would idle and drive fine without load but i'd get a miss fire when WOT. It worsened while I was diagnosing ignition system to melting plug number 6 when WOT and a consistent missfire at idle and 0 load And a new Injector solved the problem.
SlowE93
1,655
E93
6 seemed to have gunked up either be it Ethanol Gunk or Carbon build up. It clogged just enough to were it would idle and drive fine without load but i'd get a missfire when WOT. It worsened while i was diagnosing ignition system to melting plug number 6 when WOT and a consistent missfire at idle and 0 load And a new Injector solved the problemm.
That plug definitely does not look good. Now that motor is torn down, what damage was done to #6 ?
Reactions: SLOWESTN54
trevorjelam
Jul 18, 2021
13
6 showed signs of the lean scenario and had slight lower comp than 1-5 it was at about 180 while others were 195-210. But did not have any other issues. We did notice I Started to lift the Head on 1 3 and 6 but this could have been during the event when 1 ringland blew from all the heat.
SlowE93
1,655
E93
Yes but why lower CR ? Any signs of bent rod at all ? Scraping cylinder wall ? Piston not reaching tdc ? Or did it lose compression thru rings ?
trevorjelam
Jul 18, 2021
13
Ali barakat who is tearing down/ building the motor said carbon from bad injector he's assuming ring sticking. Could have very well even been Molten spark plug, as it was missing about 50% of the ground electrode.
