What car did you the retrofit on? And was that just paddles and flash or were you actually changing boxes
There was never a ROM created for it. 2009+Why should the dct wont work with MSD80?
Okay. Is it possible to buy a random MSD81, lets say from a 330i, and Flash it to inaos Version? Is there something to Keep an eye on it?
t if I buy a used z4is dct DME with CAS and keys would it work?First you'll need the new DME to be virginized / matched to your CAS and key. Then you'll need a custom MHD build from me to allow flashing of INA0S on a DME / car it wasn't intended forI don't handle the first part, but I've done the second piece for a few DCT swap customers already, works wonderfully.
Hey guys,
last weekend I did the wiring for my dct swap. Iam a little bit confused because my old X6021, X6031, X6041 female connectors that came from the transmission has 2 rows with 4 big Pins. So my original male connector has it, too. The new connectors of the dct wire have 1 row 4 big Pins and one row with 8 small Pins like the wiring diagram.
Can anybody tell me if that is normal?View attachment 22829
Yes, its been done and you might want to read through some of what is involved in that here https://bmw.spoolstreet.com/threads...d-whilst-converting-to-m3-flash-and-gws.3011/is it possible to fit M3 DSC and code it to E90 335i 07
https://www.bimmerfest.com/forums/showthread.php?t=847617#/topics/847617
Not saying you are wrong i have no first hand knowledge and have read allot of wrong info plus one part says 200ms next says 100ms but the part that interested me i screenshot about the overlapping shifts.
Yes, I posted tons of logs here and on other boards with some testing I was doing with xHP. If you want to see 6hp performance look in the xHP threads. Nobody has ever posted any log with a shift time faster than 0.400sec. The community has thousands of 6hp logs showing this, covering thousands of cars. If someone tells me the shifts are 350ms and we log 400ms then we can agree logging differences could account for that. When a claim is 2-400% different than actual results....well... we call that marketing
You have alot of insight on our trans so what's your take on pd clutches? Do you think I should be able to have full power shifts with the upgraded clutches and or be able to speed up shifts over a stock trans with xhp or do you think it will just increase my torque holding ability and not really allow faster shiftingThat's interesting. I routinely see shifts of ~200 ms in logs, even at partial throttle. When I customize my xHP tune even more aggressively and under heavy loads and higher RPMs, I sometimes even see between 140-160 ms shift times. And, that's with more speed/aggressiveness left on the table in the xHP calibration.
Even lazy, partial throttle shifts are well under 400 ms, some closer to ~200 ms:
I think it all comes down to one's specific calibration and whether or not the TCU is seeing accurate DME torque values (which some JB4 setups or non-MHD flash tunes can muddy, resulting in slower shifts and with imprecise clutch engagement on upshifts). The ZF Gen-2 6HP is capable of a LOT. It really depends on how many hours of development one is willing to undergo to achieve both extremely fast shift speeds while also accounting for shift quality. These are often diametrically opposed, especially at the extreme end of one or the other — and it requires a LOT (and I mean a LOT) of calibration development to achieve both. But, it's possible — and there are literally thousands of tables in the TCU to manipulate to achieve that. For example, the 2010 X6 and 2010 X6M have the same ZF Gen-2 6HP transmission. However, their shift speeds and behavior could not be more different. The M division invested an untold number of development hours on the shift calibration of the X6M — resulting in shift speeds that occur within the window of a single cylinder firing event; for which ignition is cut to a single cylinder. Some automotive journalists actually thought the X6M was DCT-equipped (and they talk/write about it), before being informed otherwise by BMW. Conversely, the more 'pedestrian' X6 shifts more like a traditional automatic, even in Sport / Manual modes. Same transmission. Again, for the Gen-2 6HP (and with the 8HP), it's all about depth of calibration as opposed to capability.
