I'm not sure what's going on, but yes wgdc is super high - 90's through 3rd gear and 100% in 4th
. Your stft goes very negative, so your DME is pulling out fuel from what it thinks you should need based on MAF value, which suggests you're losing metered air (a boost leak).
As mentioned above, a bad diverter valve could contribute to the high wgdc, and usually wouldn't show up on a boost leak test. But a bad diverter valve usually wouldn't contribute to negative stft, unless it was actually leaking out of the compressor housing vs. just leaking back to the inlet. Doesn't mean you don't have a bad diverter valve, just that if you do it may not be the only thing going on.
What's really strange to me though, is your boost actual actually follows target really well all the way up to shift point in 3rd gear, but then it falls on its face for all of 4th gear. It should be EASIER to hit boost target in 4th gear, because your engine rpm (and therefore airflow demand) is increasing slower than in 3rd. So why is 4th so much worse than 3rd
? It makes me wonder if your issue is also tune related? Is this a custom or OTS tune?
