where can I find .bin f30 mppk
mvon2040
hello
where can I find the .bin file for f30 mppk, or any other .bin files.
thanks
900
I'm not too familiar with f30 n55, but on n55e, only the early n55e (98gob rom) had a ppk option; the newer n55e rom (9e60b) like I have in my 2015 e84 X1 doesn't have a ppk bin. Do you know for sure if the n55 f-chassis has a ppk option? Also not sure if pneumatic or electronic wastegate rom in f-chassis matters for ppk availability?
Good luck with your search!
mvon2040
Are you looking to just run the ppk bin, or use it as a base for self tuning?
Both,
Yeah, the f30 was offered with a MPPK. It slightly raised the HP and TQ, I've found guides on how to enable the PPK for E90s but nothing for the f chasis. Not sure, I know my car is a EWG and was offered with a PPK.
900
If you can't find an f30 ppk bin, you could dig up 98g0b ppk and non-ppk bins, and open them using the 98g0b XDF from github, and compare the two, to see what's different. Those differences would give you an idea of the types of changes you could make to your stock f30 bin to simulate ppk.
