Hi everyone,
I've recently installed the Nexsys oil pressure sensor kit and I'm curious what range of oil pressure you're seeing. I've researched and from what I've seen warm idle should be mid 20s, and at high rpm 110 or so.
My range is ~40PSI at idle, and about 105PSI at higher RPM. It seems my idle pressure is high, and my high rpm pressure is a little lower than expected.
thoughts ?
thoughts ?
