Technical VanJen Turbo Pipe Clamping System
2,197
Anyone use these? How do you like them? I have a boost leak and was thinking of fixing the system once and for all. Pricey but looks convenient.
https://vibrantperformance.com/catalog/index.php?cPath=1250_1522
I have basically solid motor mounts so I should be good to go I think. Any reviews? Doesn't seem to be a ton online. 1st one to come up on my google search was one breaking.
I was thinking I would also get away from the stock C clip at the TB with one of these. Anyone have good or bad experience eliminating the stock C clip.
Reactions: JuniorB
mikeseli
140
81
2009 BMW 335i
I used and still use Tridon smartseal clamps on all of my silicon coupling to metal beaded end applications, never had any issues. Even on builds with 32 psi.
They have a 1/2" or 5/8" wide version.
The Convert
1,487
1,052
29596
I used them on all of my charge piping and intercooler when I made my setup. Never any issues. You have to be careful you don’t put in too much heat and warp the flange when you weld them on though or they won’t seal for shit.
1,929
664
I never understand how stock c clip doesnt leak more often
Brule
374
443
335i 2007 6spd manual
Looks to be similar to plazmaman clamps.
Guarenteed to stay on. Very popular in high boost cars in Australia.
They have plenty of flex.
3,613
... and they are not particularly expensive, either .... which is great as that stuff adds up.
Terry@BMS
Jan 23, 2017
462
379
Never seen these before, pretty interesting! I wonder how well they hold up long term though?
4,337
I have the alphaloc on my chargepipe by my throttle body, no c clip for me. Although, I think I want to add a wiggins or another one on the other end going toward my FMIC. The AD-E FMIC up pipe rests against the vert brace that goes through that area so its kinda tight due to a slight deflection. Currently I use t-bolts on the silicon hose which works great, but that is not nearly as convenient as twisting off a clamp.
4,337
Best parts period.
This looks like you have to use tools to remove? The alphaloc you just twist with your bare hands.
I'm about to upgrade the rest of my piping
derekgates
740
375
NW FL
derekgates.us
2011 335is
View attachment 35607View attachment 35608
Daaaaamn that is sick!
I have such a hell of a time keeping my charge pipe oriented correctly with TB and keeping it that way. This locking system looks fantastic. I have no clue who could modify mine to handle that though.
4,337
Honestly just anyone who can weld aluminum.
Reactions: derekgates
