N54 Tunerpro n54 n20 map flatlining at 21psi
Simonn54germany
Hi guys,
im sure someone has had my excact problem but ive been searching the forums. I found a couple of threads about this but i didnt get it so i hope someone can help me out.
im pretty new to selftuning so pls be gentle. I have hybrid turbos and all the suporting mods. I have a n20 tmap sensor, i have raised the boost target to 1.5 and i checked the n20 option in mhd. I tried playing around with the map voltages but didnt get any different results.
The Car flatlines at 21psi for the boosttarget. The Car doesnt reach the targeted load but easily reaches boost target so i presume its an issue with the tmap.
oh and im on i8A0S in case that is necesary to know
and sorry for the lack luster english im german
Jake@MHD
Nov 7, 2016
1,599
2,071
Philly
You need to use the 3-cell tmap scaling patch, and then retune most of the tables with load as an axis, as the boost <> load relationship will. have changed from roughly 140% up
TiAgAu
150
62
08 335i
I was actually looking for 3-cell tmap scaling patch a while ago. Is seems to be removed from all the latest xdf updates atleat the last 2 updates.
Found i had an older version which had it though.
