Tune
Invisiblewave
Hey there y'all,
I made this account very recently and just had an inquiry about tuning BMW's as I would like to get into it myself. I know there are many professional tuners on this forum and was wondering if someone could mentor me or if anyone could offer me any advice, I would really appreciate it.
Thanks.
oVeRdOsE
34
13
DIY tuning will be way easier and ''safer'' with a JB4 and a back end flash with MHD.
after reaching 2 tuners for my single turbo and not have the results I had with a mhd flash on my stock TT, I started to read and found the 2 thread there.
I got the lasted JB4 and a map from Terry. Even if he dont edit .bin maps, he helped me to edit them, timing wise with tunerpro.
Then log, and log and log, and compare result with other on a software called ''virtual dyno'', until I reach similar results as guys having similar setup.
From my reading, jb4 map1 to map5 are pretty solid and dummy proof. You'll be close to what a tuner can do, but not quite there as a real 100% flash set for your setup. But : cheap, DIY, and meth / PI friendly. (I use meth)
I knew that, but for me this was plenty already, got 601whp on map8, and 485whp on map 3. I keep the map 3 99% of the time, more usable.
I wish to have better low RPM response, but this is over my knowledge at the moment. I was expecting more low end power with a small 6262 gen2 divided ballbearing. Ill check that next spring.
I.e. my fuel line from the vertex valve split (wrong line used), LFP drops to 40psi, JB4 put the car on map1 automatically. I love those safety. Also you can still got MHD option, like single bank fuelin, launch, 2step, etc.
Imo it's a good start, then with experience you can jump into self tuning your .bin file and get a full tune flash to your taste or even go with a maxxecu.
SlowE93
1,761
Just a plane ticket away !
E93
Glad you got it sorted out ! 1 tune was Treb correct ? I remember high boost but low power was your issue ?
