Switchable Maps via MG Flasher - update 1.3.10 BMW B58/B48
MG Flasher is pleased to announce our latest innovation! Our team has recently developed a way to switch between E30 OTS and regular octane fuel OTS maps without the need to reflash the vehicle! Through a simple combination of the Brake Pedal, Accelerator Pedal, Traction Control Button and the Driver Select Switch you can quickly select between E30 and Regular Octane mapping.
Watch instructional video!
Instructions:
Enabling E30 Mapping:
1.The car must be in the ignition ON position with the engine not running
2.Select ECO Pro from the driver's select menu
3.Depress the brake pedal while holding the gas pedal to its maximum position
4.After a few seconds the RPM in the dash should show 1000 rpm (indicator of
E30 Map Selection)
Enabling/Reverting to Regular Octane OTS Mapping:
2.Press the Traction Control Button once
4.After a few seconds the RPM in the dash should go from 1000 rpm to 0 (indicator of Regular OTS Selection)
Verifying Your Selection:
If at any time the user would like to check their currently selected setting, they can do so via the MG Flasher Logger and regard the Ram Variable “selected state for map switch” or they can simply perform the following procedure:
2.Select COMFORT from the driver's select menu
4.Immediately you will notice that the selected value will be displayed on the instrument cluster;
Switchable Maps function is 100% free with a purchase of any E30 OTS maps and is available starting with MG Flasher App update 1.3.10 and E30 OTS maps ver 2.5
Thank you all for taking the time to view our newest innovation and we look forward to announcing more features as time goes on!
MG Flasher Team
Instructions:
E30 Map Selection)
MG Flasher Team
