I've got a 2014 335i that I've ran a couple logs on after switching to the e40 plus hpfp MHD tune. Car pulls hard and running good. I wanted to see if I could get some that better understands the logs than myself to take a look at them. Thanks
Car is FBO, new Bosh plugs,new elder coil packs, DS15 dorch hpfp.
I have a stage 2 lpfp and arc terminator ekp fan to keep the ekpm cool and adjust voltage but haven't installed it yet. Not sure if I need the lpfp. Car has e45 in it. I test the e % at the pump before filling. Just had the valve cover replaced,oil pan replaced, 2 boost leaks fix, transmission fluid replaced. Thanks for taking a look at the logs.
![www.spoolstreet.com](https://www.spoolstreet.com/data/assets/logo/sssocial.png)
