Spool Performance N55 upgraded high pressure fuel pumps FX-150
Oct 21, 2018
29
93
E92 335i
Spool Performance is really excited to introduce our latest product offering to the F-series and late E series N55 community, the Fx-150 high-pressure fuel pump upgrade. We have been testing this for almost a year now and here it is finally!!
What is the FX-150?
The FX-150 is an upgraded high-pressure fuel pump for the F series N55 and B58 motors. The pump features a bigger bore size than stock that translates into roughly 50% more flow when compared to stock. The pump is completely E85 compatible and fully plug and play with no cutting or splicing of any kind required. The added flow will let you run much higher ethanol concentrations and also allow fueling for bigger turbos.
Why do you need it
The stock HPFP on the F series and late E series N55 motor is severely limited in capacity when trying to tune and raise the output of the motor. The FX-150 adds 50% more flow to the equation, raising the fueling limits on the platform and helping you run bigger turbos and/or higher ethanol concentration blends.
Tune changes
Tune changes are required to use the FX-150 system. The changes are available with all major tuners and Spool performance will provide the necessary calibration changes needed for the same upon request.
Available for order at http://spoolperformance.us/index.php?route=product/product&product_id=77
F87Source
332
151
Canada
2017 Bmw M2
Very nice! what is the price for the FX-180? Just curious because another company has a similar flowing one with apparently life time warranty (that's what theyre saying) for only $1700.
boostd4
19
2011 BMW 335i N55
How do we determine if we have a late N55? I'm guessing my 2011 N55 E90 (build date 01/2011) is an early build date?
Oct 21, 2018
29
93
E92 335i
Reactions: F87Source
Oct 21, 2018
29
93
E92 335i
So any N55 with a build date in early 2011 has the N54 style HPFP. If you're looking to upgrade that then you would need to look into the Helix overdrive unit. You can always contact us before purchasing a product and we will make sure you grab the right one for you car
scrllock
267
153
2011 335xi
Any e85 horsepower numbers you want to give? What's the difference between say the fx-180 and a dorch stage 2?
