Selling the following:
6-bolt SPEC SB53A-4 15lb LWFW to suit a N54/N55/1M , with a brand new lining from SPEC . These are made for use with an OE SAC-style PP, so perfect for mating with a 550i clutch. Comes with removable center nipple so this can be used with both N54 and later N55/1M style transmissions Only removing this because I am going with a twin plate. asking $480 firm
ACT BM8-XTR6 unsprung 6-puck clutch, rated at 702lb/ft. Lightweight/low-inertia @ 12.8lbs to help with high rpm engagement. Literally 11 miles on it, not yet broken in.. Removed because I am going with a twin plate. Asking $480 firm
Figured I would post here before listing this on the FB Group. If you happen to want both price is $900 firm. Pics to follow...
