Hi guys, i have a small problem regarding my PCV system.
My high side PCV is catch can then VTA.
My low side was stock until i plugged the 6 holes in the head and did a external low side PCV 2 days ago.
My problem is now i get a lot of smoke coming from the VTA high side at idle/low loads, meaning the crank case is under pressure.
Somehow plugging the ports and routing the low side externaly lowered the crank case vacuum...
I really don't understand what is happening, if someone has any idea it would be really appreciated.
