FS Single turbo Th400 swapped E92 for sale!
MilesG
This is my 07 335i that has been th400 swapped with a single turbo settup. It’s built for drag racing but with the anti lag it does well from a roll as well. It has ran a 6.2X not even turned up yet with its current setup in the 1/8th. The car is very reliable you can drive it anywhere just fine and still has AC, heat, and radio. With some weight reduction this is a world record stock N54 car without a doubt. Made 760hp on my dyno on 29 Psi.
Build list:
Stock N54 engine with new valve cover and gaskets
Speedtech single turbo kit
VS racing billet 67/68mm turbo
FTI lvl 5 TH400 with trans brake
Custom built stall converter from cameron's converters
Brangers racing th400 billet adapter kit
B&M th400 reverse pattern shifter
Trans brake and everything wired into the center console
15 in conversion with brand new 275 in MT ET street R tires
M3 3.15 diff swap
Full aux fuel system and 525 in tank pump
750cc port injection kit to support 800+ hp
Runs full e85
Flex fuel sensor
I have forgot a ton of little stuff that has been done but feel free to ask questions. This car has 30k in it all in the last year.
MilesG
Interior pics of the th400 swap
