If you own a Schwaben BMW Scanner from Foxwell Technologies, and you need to do the transmission reset procedure here are some details you should know.
In the transmission settings under "service" or "control" section, there are two transmissions available.
1. 6HP19 - For anyone with the 6HP19 transmission.
2. 6HP19Tü - For people with the 6HP21 transmission.
If you have a 6hp21 unit, you should choose the #2 option. BMW & ZF use different nomenclature to name the 6hp21. BMW calls the 6hp21 unit - 6HP19Tü which means basically is the technical update to the 6hp19.
So whether you are deleting adaptations, or resetting to zero value - use the 6HP19Tü if you have a 6hp21 transmission.
I am going to do my reset and relearn procedure tonight on my new Propulsive Dynamics 6HP21 unit. Keeping fingers crossed!
VT
VT
