Put the car on the dyno today. Wondering how much more power I could make with a proper tune
twinturbos
287
77
E92 335i MT
The numbers are decent enough. The power delivery is very weird... overboosts, cuts fuel, goes back at it.
Running DOCRACE with 6266BB
fuel-it stage 2 LPFP
R8 coilpacks
New HPFP
New index 12 Injectors
94 + 50/50 WMI
JB4+MHD BEF map 4 23psi
555whp, 444wtq on a mustang dyno.
What do you think ?
I'll grab the logs from my other phone and post
R8 coilpacks
New HPFP
94 + 50/50 WMI
What do you think ?
Seems about right my friend made 630 whp on 24psi on full e85. Doc race precision 6266jb, dual walbro 525, helix overdrive, index 12, precision race works coils
Reactions: twinturbos
yuli8466
99
23
R8 coilpacks
New HPFP
94 + 50/50 WMI
What do you think ?
mustang dyno read are different from dynojet.
2,197
Well a 'proper' tune is small money so I see no reason not to. Especially if you can't figure out the "power delivery is very weird... overboosts, cuts fuel, goes back at it." issues you are having. Given what you have spent a custom tune will be able to get more out of your set up than an off the shelf back end flash + JB4 I would think.
Once you post the logs perhaps something will become apparent.
Payam@BMS
412
265
34
Not saying the JB4 is the issue I actually would like to keep it but the tune seems inconsistent. Need to fine tune it.
Log looks okay.
I think I see the issue with boost control, duty bias is not set to 50 as it should be across the board.
Set that, lower FF to 10 and get another log. We'll have to rework that side, a couple logs back and forth.
twinturbos
287
77
E92 335i MT
Log looks okay.
Thanks ill try tonight
