Port Injection 700cc tuning
slowhoss
Hi
Doing a little self tuning to learn a bit, although ultimately I will probably need a custom tune done for me.
Right now I am using the 750cc basemap on reflex plus. The problem is I have DW 700cc injectors.
I was wondering if anyone could point/steer me in a direction
So far I’ve adjusted the duty cycle and kind of got the log to be in the ball park. I’ve attached two recent logs, not the best since I could do a full proper pull.
Stock turbos
Manual Trans
MHD V10 Stage 2+ E50 map
PI plate with DW 700cc
Stock pump w/ Secondary pump (450) hobbs activated(for now)
Full “bolt ons”
E content sitting at about 65% (want to pump straight e85 into the tank no mixing)
External PCV with ports blocked
  • Solid2ndgear?_2024-08-01 01_48_20 INA0S v10.0 stg 2+ e50.csv
  • Mayb?2024-08-01 01_43_21 INA0S v10.0 stg 2+ e50.csv
