Not hitting boost target
Butterwheelz
Having some trouble hitting target boost.
The car won’t make anymore boost than 3.5psi under 3700rpm after that it’ll spike to 11psi for about 200rpm then taper down
Currently running MHD stage 2 v1.60
VRSF charge pipe intake and catless downpipe
Stock IC
Did notice a few weeks ago I had a code for my Diverter valve being clamped shut. Was also told my turbo might be going out as it’s already at 115k miles
Here’s a data log I ran
750
At minimum, it looks like you have a boost leak. Stft goes extremely negative during the pull. That's likley due to metered air leaking out through the boost leak vs. going into the engine, so the DME has to cut fuel to try to keep AFR on target. I'd start there, and see how things look once you correct the leak👍
Butterwheelz
Thank you I’ll start looking
I really need to learn how to read these graphs
