Technical New N54 Engine Install...NO SPARK! Help!!
IQraceworks
268
157
Missouri
07' BMW 335i
Just got the rebuilt engine installed in my 07 335i. When I try to fire it up, it just cranks and cranks..but doesn't fire.
I have LPFP (82psi) and HPFP (2,200psi), and NO CODES. I've checked every fuse I can find, all are good. I'm not getting any spark out of the coils.
I checked continuity from the frame, to the block, to the injectors, to the coils....everything is grounded as far as I can tell.
Any idea why I'm not getting any spark, and no codes?
Any help would be great!!!
I'm betting the timing is out because the VANOS adjusters are reversed. But if it really is no spark, maybe a missing ground strap.
IQraceworks
268
157
Missouri
07' BMW 335i
Well, I figured it out.......but it was mostly just luck. After checking grounds, wires, connections...everything I could think of, I had just about given up. Then I figured what the hell, might as well try to reflash the tune. Well...that did it. As soon as the tune got flashed again, I hit the start button...and the engine fired up and came to life!
Not sure what the deal was...maybe after sitting for almost a year with no power, something in the DME got corrupted? Glad it was something simple......
Reactions: NoGuru and wheela
