New here, ran a PB in my N54 335is DCT today - 10.59 @ 132
rev210
242
146
335i - 08 Coupe .
Great times set in luxury mode(full weight). As it should be 😄
Post up that mod list dude.
Another good time set with twins, which ones have you got there?
Grip Grip
Thanks. Mods are DAW 775RS turbos (24 psi), 3" DP's, 3" exhaust, Port injection - 600cc injectors, stage 3 LPFP, 7.5" Intercooler, Motiv tuning (Chris Kontos) running E40, and XHP for the DCT. It's targeting up to 27 psi at times but sees around 24.
Reactions: rev210
rev210
242
146
335i - 08 Coupe .
Thanks. Mods are DAW 775RS turbos (24 psi), 3" DP's, 3" exhaust, Port injection - 600cc injectors, 7.5" Intercooler, Motiv tuning (Chris Kontos) running E40, and XHP for the DCT. It's targeting up to 27 psi at times but sees around 24.
Good setup. Assume fuel pump upgrade, AIC controller etc and the usual other bits. Whats the rear setup ? Diff/Tyres /diff lock down kit/suspension etc
Mine ran a similar time, in full weight trim on non drag radial ( yoko AD08r) , running pure stg2 hiflows . With M&H Drs or Mickeys and a dialed in rear end you may touch low 10s on an E85 tune. 👍
