need help with LOG,, afr go too rich!
marvix
12
new data....
car change fuel mode to 6,, then start time corrections and missfires... on 4,5,6 (bank2) + error codes: super knocking cylinder 4...
it may cause bad MOSSFET or injector driver in MSD80? It only happens in long pulls,, 5th or 6th gear around 6000 rpm..
vadonchez
32
11
I'm asking myself how is it possible to have such low MAF(g/s) for this boost level. On V7 2+ OTS MHD I reach 330g/s@6krpm with 14-15psi. On your log you only have 320g/s @6000rpm with 23psi:confused:
Is it du to N20 TMAP?
Log your LTFT next time.
marvix
12
yep iam on 3.5 bar sensor, but dont knew how much g/s may it be,, MAF is only calculated and isnt used to anything i hope... car has only map a tmap sensor,, variable calculating with load to show MAF
Just the result of a bad tune. Probably catalyst protection kicking in. The whole tune looks lazy in general.
Ask the tuner to fix it and if he can't then ask for a refund or name and shame.
