Need help with intermittent codes/warm start issue
whyzee125
51
22
Hey guys,
I've been on e90post for 12 years but I'm relatively new here and this is my first time needing technical assistance. About 6 months ago, I started getting a random/intermittent 2ABD code on about 1 in 10 warm starts. No symptoms and if I'd clear it, the codes/reduced power mode wouldn't come back until a random warm start later. Then, on occasion, it started being accompanied by 2D2E.
It seemed like when the weather became less humid, they went away. I went a solid 3 months or so with zero codes and now that we're in the cold and rainy winter, they're back, seemingly about 8 in 10 starts, warm or cold. It's also become a little tough to control the throttle at very low RPMS, like parking lot speeds. It's pretty jerky and is affecting shift quality greatly. At anything above about 10% throttle, it drives completely normally and never sets any codes during driving.
Now here's the weird part. It seems like the exact time these codes got way more persistent, it's now developed a warm start issue. Cold, it cranks right up every time and when fully warmed up it cranks right up every time. But if you leave the car sitting for more than an hour or two, it has a very difficult time cranking and sometimes takes up to a minute or so, and is super rough requiring some throttle to keep it going. Once it smooths out and the codes are cleared, it's back to normal. I've viewed the MHD gauges one time when it wouldn't crank, and there are no fuel pressure issues (I initially suspected maybe an FPR issue).
Relevant info:
- 2009 335i 6AT w/ 112k miles
- Stock turbos
- Custom Wedge tune @21psi
- 3.5bar TMAP with BMS harness, confirmed secure and cleaning connections did not fix it
- Full e85 w/ MMP PI V2 (plate style with Genuine Bosch injectors, confirmed not leaking)
- ER CP with Tial BOV
- Stock valve cover, 1 year old with RB PCV
- BMS oil catch can
It does it on both pump gas and E85 tunes. The 3.5bar TMAP option is baked into my e85 tune but I used the setting in MHD when running pump gas. No change either way.
I've seen a fair amount of people with the same codes, intermittent like mine but I've seen very few answers. The car has had all existing mods since about 2018 and this is a new issue. I found one user who solved it by new intake manifold gaskets, one with a new throttle body, and many who have not solved it. Finally, @KnighTT had very similar symptoms and it was related to his PCV/OCC system but his was very heavily modified whereas mine's close to stock and the issue is new so I'm stumped.
Attached are some screenshots of the codes and a few datalogs as well. Any help is very appreciated!
Cold start NOT in limp mode (this was just before the codes began to return)
Cold start with both codes and in limp mode
A normal 3-4 pull
Thank you!
I'm pretty certain both of those are related to the TMAP sensor.
2ABD is a plausability check of the ambient pressure sensor and the TMAP sensor. They should read the same when the engine is off, but that code means they are reading different values.
2D2E is a plausability check on the MAP reading which is the manifold sensor. This looks at the throttle angle and the TMAP to check if the MAP sensor is valid.
Either the scaling on the TMAP isn't set up right or the sensor is bad. Since you are only targeting 21PSI you are better to just use the original TMAP sensor anyway. If the problem goes away then you know that was the issue, otherwise you should check the MAP sensor out. Also add boost mean to the logs since that shows the TMAP sensor value.
whyzee125
51
22
Thank you very much, @carabuser . I will enable boost mean and see where that gets me. I should have the stock TMAP sensor too so that would be an easy way to rule that out. Car has been parked this week but I'll dive into it this weekend and report back if I'm successful!
ktb_e92
76
38
Indiana
2007 335i MT6
Have you brought this up to Wedge? No shame intended towards Wedge at all, but throttle mapping seems to not be an uncommon issue that recurs when running their custom tune based off of several sources I've read through, along with seeing multiple friends in-person deal with it too. Their cars will either have fluctuating idle and/or stalling after the first few minutes post-cold startup, and sometimes post-warm start along with that throttle angle code.
I've personally dealt with it, but only once, and I'm not tuned by Wedge. It would idle weird upon startup and at its worst point it'd idle like a big-cam V8 until I shut the car off, cleared codes, then restart it. This was months ago, and has yet to come back because when it was happening, my tuner requested a normal driving log so he could most likely revise some of the throttle settings before sending a new file back to me. Keep us updated
whyzee125
51
22
I actually haven't; while I thought it was tune related at first, it does it on OTS maps, my 93 map, and my e85 map. I did make some progress though--I'll post below!
whyzee125
51
22
I enabled boost mean in MHD and logged another cold start. It looked like the boost mean didn't record anything for a while, making me think it's a bad sensor or a bad connection? I watched the gauges for a while and it had a little flicker of a reading twice. I cleared the codes and then it was reading after that.
Here's a cold start log (in limp mode) and then a normal pull log after clearing it.
Cold start: https://datazap.me/u/whyzee125/e85-cold-start-w-boost-mean
Pull: https://datazap.me/u/whyzee125/pull-after-clearing-2abd?log=0&data=3-20
ktb_e92
76
38
Indiana
2007 335i MT6
Weird how your boost mean wasn't reading at first. That could indicate a possible issue with your MAP sensor which could explain your car acting up occasionally, I doubt it's your TMAP. I've never had any issues with the same TMAP kit that you have.
And okay, if you haven't contacted Wedge I'd do that as soon as possible because you can only troubleshoot so much, especially throttle-wise, before they need to be involved. This is because they're the tuner and have lots of access to the parameters, within the throttle system, that you don't have. Keep us updated
whyzee125
51
22
I appreciate the reply but this shows it's definitely not tune related. I've been running the same tune since 2018 with zero issues until 6 months ago and it also does it with MHD un installed.
The fact that the TMAP is reading intermittently seems to definitively show that it's either a TMAP connection issue or the sensor itself going bad. I'm out of town now but I'll dig into it next weekend and keep you all posted!
whyzee125
51
22
Ok, eons later I've got an update! Got a new genuine 3.5 TMAP sensor from Island Road and started to replace it. Pulled out my ER charge pipe only to see a big crack in the mouth where it goes over the throttle body!
Got a new charge pipe on order--not 100% sure whether the sensor or the crack is the issue but I'm thinking the crack. Might replace one at a time just for curiosities sake but between the two, it'll get fixed I'm sure!
whyzee125
51
22
Car is 100% fixed. Thank you to everyone who replied and especially Car Abuser for his crazy amount of wisdom on this platform. I'm not sure if it was the TMAP or the charge pipe, but replaced both and it's back to running like a top with no codes.
ktb_e92
76
38
Indiana
2007 335i MT6
Awesome! Sounds like that crack was letting unmetered air in post-TMAP which was skewing your fuel trims & throttle control.
2D2E can be pesky but most of the time is related to reasons like your situation, failing MAP sensor, or intake gasket leak.
Keep us updated in a few weeks on this thread if you would, it'd be good to hear if everything is still normal especially after throttle adapts for a few days post-repair; a good handful will find a solution to the code 2D2E / throttle oscillation for it to eventually come back. 🙏
whyzee125
51
22
It's been about 400 miles and 2 weeks--so far so good. Running really strong, no codes and my MPG increased too!
Reactions: ktb_e92
zura598141408
Hey guys,
Relevant info:
- Stock turbos
- BMS oil catch can
ჩვეულებრივი 3-4 აწევა
გმადლობთ!View attachment 104954
Hello, did you have the ECU connector loose?
whyzee125
51
22
Well @ktb_e92 called it.
The issue is back--what in the world? As a quick recap, I thought it was a failed TMAP so I ordered a new genuine BMW one and found that the o ring was completely gone on the old one. Between that and the cracked ER chargepipe, I thought I'd gotten it. Oddly, without resetting any adaptations, the car drove 100% better and was completely problem free for more than a month. Last week it started doing it in extreme humidity again and now it's back to doing it almost everytime the car starts. The jerky throttle is back, random warm starts are difficult, and 2ABD about 8 in 10 starts accompanied by 2D2D about half the time.
  • Sad
Reactions: ktb_e92
ktb_e92
76
38
Indiana
2007 335i MT6
I would get back in touch with Wedge and explain exactly everything up to this point. After, mention specific throttle settings or even "lobe separation angle" to them and see if that helps open a door to getting some revisions in hopes that it's masked for good.
Reactions: whyzee125
Not sure you can tune out those kinds of issues. Something funky with the sensors there. Correlation issues between the pressure sensors.
whyzee125
51
22
I'm also inclined to think it's not the tune as it does it regardless of what tune is installed or even if MHD is uninstalled. I'm thinking I must have an air leak somewhere or it looks like a failing throttle body could be causing it too.
That being said, I didn't think it would come back and ktb called that so I don't want to discount his advice haha
895
It sounds like an intermittent connection issue with those sensors. Perhaps the wiping action of disconnecting your old sensor and connecting your new sensor cleared enough crud from the harness contacts to read the new sensor for a while. But if the harness contacts were pretty dirty/corroded for some reason perhaps it's now causing intermittent connectivity issues with the new sensor? Maybe clean/check the contacts for those sensors at the harness end. Or maybe even the harness itself (vs its contacts) is starting to develop intermittency issues?
At a place I used to work we had an intermittency checker where you could connect a cable/harness and jiggle it around to detect intermittency issues with the cable being tested. I didn't use it myself so I don't know a lot of details, but I know they exist.
