Datalog N55 low power and MHD noob
seb_n55
Hi guys,
I struggle wit low power, some mild overheating ( oil temperature ~120*C) and incre fuel consumptio, 2016 N55 B0 here. I started recently using MHD to look at things but I am a bit stuc. I did a reading and I was thinking you might have some insights on it.
Just to mention, I did a smoke test and found a leak on charge pipe connection, which I believe I fixed. I changed recently the plugs (OE), coils ( Delphi).
I also think I might have an injector leak, since on cold starts the idle drops to the point of stalling, then jumps towards 2000rpm.
Thank you so much!
Seb
https://datazap.me/u/sebastiani/n55-run1?log=0&data=
  • 2024-05-16 11_12_16 000021571DB401 Unknown.csv
