Data in one place some people may find useful or of interest.
If there are more available cams with known information I can add to the below, a summary of the the camshafts is in the table and relevant data sheets attached if available.
Schrick did not provide me with a data sheet for the "Low Lift" and I have not asked VAC for it, the assumptions I made should be pretty close.
VANOS has 55 degrees advance available on intake cam and 45 degrees available retard on exhaust.
Depending on the source of information and reference lift some angles differ by +/- 1 degree in other documents.
For US guys used to seeing duration @ 0.050", 0.050" = 1.27mm so it's not exactly the same but similar.
If people have actual profile detail / data that would be great to share as well.
