n54 single turbo drag build
Silentkiller335i
116
178
Thought id finally share some details on my build. These are old to present pics and will be updating as i go.
Goal: run 9's
Hp: 800+
Car weight goal: 2850
Specs on the car: 07 e90 335i
MHD only
JB Custom twin scroll turbo kit 6466
Controlled by boost box/mac
Manual swap w/ Cea shifter
clutch launch control
Wot box/ 2step
Kirkey drag seat
Built rear end
15" brake conversion kit
Champion billet 15" beadlock wheels
275/60r15 e/t street radial pro (street)
bias ply slicks for the track
17x4.5 vision
Mickey thompson skinnys
Vrsf 7.5 race intercooler
PR ignition kit
Agk poly mounts/vader soultions trans mount
Billet aluminum subframe bushings and diff
Brallie 17lb light weight race battery
derale oil cooler/motiv thermostat plate
custom stage 3 fuel system
AD engineering PI
and adding more as I go but that's a general idea of what it consist of
My car during tx2k17 on my old turbo kit i built
Turbo build parts
Manual swap time !
Mock up on twin scroll build
ofh painted gloss black with motiv plate
Custom made 02 sensor bungs to dissipate heat
Turbo manifold done and ceramic coated
Vrsf 7" (old) vs vrsf 7.5 race huge difference, and fin pack is much more dense
Champion billet beadlock wheels
Braille 17lb agm light weight battery vs old pos
Kirkey drag seat installed with vac billet seat mounts
Little hood construction going on (rough draft)
Finshed and all smooth.now ready for some paint
Rear end never broke on me but not gonna chance anything at the track. Well i plan to run andys 8.8 but in the mean time gonna give the stock drivetrain all shes got!
So the plan consists of cryotreatment.
Driveshaft,cv axles, ring pinion fully disassembled off to cryotreatment
Akg poly mounts paired with VS trans mounts nice products guys
Bkc forward facing manifold. Its beautiful
Subframe out doing all billet bushings for diff and subframe. Such a pain in the ass!
Engine bay porn
Nov 5, 2016
615
625
Bay Area
I love that you think a Single turbo E90 is going to run 9's with a 6MT. We have had an 800+WHP E90 fully prepped for the strip down the strip many times. The one time we would have prob ran a 10.6 or so, the car crossed the center line, and defaulted. Going to take a lot more than what you showed to get that car in the 9's, but it's a sick build regardless! Should run mid 10's consistently if the driver is any good.
Silentkiller335i
116
178
Whats the point of having a build if you dont make goals?
On paper the car should do it with ease. #1 struggle is getting out the hole.i will have everything set up to do so. Youll just have to wait and see me do it. :grinning:
2,255
806
Sick build. Good luck.
*Shakes head.
Reactions: Silentkiller335i
dyezak
1,767
1,518
Plano TX
335is
This is the sad truth. The 6sp transmission has been proven to be strong and reliable many times now.....but quick is not its forte. But prove everyone wrong. Someone is bound to do it; hell, just through enough power at it or do something crazy like a 2.86 rear gear set to limit your shifts and the impact they have on ET.
Abacus38
643
385
Tampa/Orlando, FL
2007 Ti Ag 335i
Once they finally get rid of that pesky tq limit bog we should be able to hit that time. My problem is the bog when shifting 3rd-4th
