Does anyone know how to log the pressure sensed (or other parameter) by the second MAP sensor mounted on the intake manifold? Been trying to find a boost leak. Replaced vacuum lines, intercooler o rings, pre throttle body MAP sensor o ring, charge pipe, DVs tested, rear turbo boost solenoid, still cant find the problem. Could be turbos but started after OFHG replacement so I am hoping if I have cracked the intake manifold or pinched manifold gaskets, I should be able to see a pressure drop or behaviour between pre throttle body sensor and intake manifold sensor that indicates a problem. WGDC PID gives up after first pull.
