Posting a feeler for my BNIB Schrick cams for the N54. Specs on the cams are 268/268 Duration, 11.5mm / 10.5mm lift. These cams DO NOT require aftermarket pistons or even titanium valves (and you might even be able to get away with stock springs depending on your rev limit), so not only could you save a couple thousand on supporting hardware but you could get them installed without needing to take the Head off and save a bunch on labor. These cams should be good for roughly an extra ~15-30% HP depending on mods and tune, in addition to an extra 500-750RPMs depending on if you do or do not upgrade the valves. From VAC these are $1500 before shipping charges, so this could be an excellent deal for someone.
I'd like $1100 + probably shipping.
I dont necessarily *want* to get rid of them so if I just get lowball offers I'll take the listing down, but there are other things I want done before the cams get put in so I'm considering selling. Alternatively I may be willing to trade for a similarly priced item, or another item + cash with stipulations.
