Not bad at all. Log looks clean. Curious to why map 6 target values are 26psi at 5k+ rpm, but log shows target at 24psi.
Also FOL at 31 ? Why ? It works fine but curious as to why that value. JB4 should lock FOL under 40. Self adjusts from 40 on up IIRC.
Also, good luck with ringlands.
Can you post the dyno sheet ?
Edit: all boost values commanded are under by 2 on the log.
At 18 it actually targets 16
23 is actually 21
26 targets 24.
Etc
