N54 compression ratio
Rve
What compression ratio would you recommend using with 93octane/98ron.
With twins. Like pure600/hydrahp800gen2
Use 10.2 or 9.5
And would i see a lot off difference with tq down low or spooltime?
surge89
11
lower compression allows you to run more boost but to a detriment to low rpm performance if you have access to e85 then 10.2 no brainer
mwpa71
54
Stock compression ratio with those small turbos..with large single 9.5 cr would be a great option.
Rve
I dont have access to e85. So that is why I want to lower it
BloodyZ4
56
37
Germany
Z4 35i DCT
I would go 9.5 since you are gonna skim the head and block that's going to increase compression.
