Motive reflex plus issue
Dervale90
Hello everyone, currently a new member,
So my story is, car is a 08 bmw n54, currently running fbo included motive reflex plus ive try to fallow all steps needed to make this thing work but im not sure what im doing wrong or missing, im currently using a tuner, so i didnt used the starter maps, so my tuner sent me 3 maps, hex file, bin file an ecu maps for running ethanol an 93oct, downloaded all 2 files to turner pro rt. Then open MHD click motive reflex in the drop down menu, flash vehicle drive it around all seems fine take pull car shuts off restarted, all seems fine. Other than car won’t accelerate pass 3k saying low boost, check every connection. find some small leaks but nothing major, all connector I’ve check all seems fine, I’ve also notice if I disconnect the boost solenoid the engine would accelerate past redline, with the connector connected to boost solenoid car idles fine but won’t rev pass 3k after lifting foot off accelerator goes into limp mood. I’m not sure if I needed to adjust anything in turner pro like boost or anything, any help would be appreciated, it’s bin 2 months now on this thing. Tuner seems to respond a lily bit too late for me at times so I’m trying to help myself by asking you guys to guide me thanks again Anyone
Reactions: lxzndo
lxzndo
Bumping this in case you found a solution or someone else has. Same issue
