MHD Logging Glitch
1,628
I experienced a logging glitch several times. A number of data channels suddenly glitch out and record an absurdly high value. Noticed this for the first time.
Monitoring dials would also record the max figure and rescale.
Using MHD Orange WiFi and iOS MHD on iPhone 12 Pro Max.
Any ideas what’s going on?
It looks like the values are maxing out momentarily. Could be a glitch in the IOS app since I can't think of a scenario that would cause the DME to respond with incorrect values.
1,628
Agreed. In the iOS or perhaps the WiFi signal. It’s never happened in then hundreds of logs I’ve done over the years with my Android phone plugging directly into the OBDII port.
IQraceworks
259
153
Missouri
07' BMW 335i
I had an issue like that once. I had to put my phone on airplane mode....that fixed it. Apparently the phone was doing stuff in the background, and trying to connect to other wifi sources. I ended up going back to using the actual OBS cable...much more consistent logs.
1,628
Makes sense! Thanks for your input.
