MHD Flex Fuel with Motiv Reflex+
Swerve
I have been running MHD with the MHD flex fuel kit and have recently added PI with the Motive Reflex+.
The issue I'm having is that I cant read the CAN flex fuel signal on the Reflex even tho I have applied the N55 MHD CAN patch.
Any suggestions on this or do I need to splice into the MHD kit and run it to the flex input on the Reflex+?
WOT808
81
56
E90 335i
The Content Sensor needs to be wired to the Reflex. I moved my content sensor to the union near the transmission/firewall on the driver side using the PR 360 fittings.
hotbeer
Nashville
I also have reflex+ with flex fuel sensor and port injection all setup. I can run e85 but cannot read the ethanol content via CAN on MHD either. Did you figure it out by chance?
