@Tedbuildiy I think I was wrong. Look at the two links below. The first one describes all the part and mentions the lower wishbone is "bit longer and curved slightly to give more negative camber (adds .75 of negative camber)." The second link is a DIY showing the specs you can expect. About -1.5 to -2 degrees.
M3 Front Upper+Lower Control Arm Upgrade - Left and Right - E82, E9X
www.turnermotorsport.com
DIY M3/OEM Upper & Lower Control Arms DIY Modification
www.n54tech.com
So it looks like you will end up with a bit more negative camber. The alignment shop might not be able to get 335 camber specs. If your happy with tire wear, have them set it to the least possible, but equal side to side. The least possible with the M3 arms should still be more than the stock 335 specs.
