M3 bits - Part numbers and torque specs
Bnks334
530
343
This PDF depicts the front and rear suspension. It indicates which item number the M3 bits you want to retrofit are. It also indicates the amount of torque that should be used while performing the retrofit. This PDF combined with RealOEM will get you everything you need short of the install guides!
  • m3 bits + shock + springs.pdf
