Looking for MSD80 RSA delete
That4chanhackerguy
Hey there I’m looking to tune a car with a MSD80 equipped and BL is no longer posting RSA deletes for MSD80 I was wondering if anyone had one.
You'll be fairly limited using just an RSA delete as it has the stock software. Probably good to about 14psi due to the limitations on target airflow. There's also the physical limit to the boost target at 1.28bar that needs patching too.
I've attached the basic RSA bypass in a zip. You would need to build your own 0da file to flash on top of this, just be aware you need to correct the checksum and ECM3 if you make changes.
  • I8A0S_RSA_Bypass.zip
thanks for dropping this in, this did bypass however not delete like bimmerlabs
It's the same exploit that everyone uses. Cobb, mhd, bimmerlabs, kess.
Nobody deletes the RSA, that's just bad terminology. You just force it to return a positive result.
That4chanhackerguy
I’m getting a different result so I have some MSD81s and MSD80s when I apply the bimmerlabs exploit I am able to do a specific task. I am able to use another tool however I can’t use that remotely. It would be cool if there was a .bin to 0PA converter so I could reflash that program space
rjahl
BMW Z4 35is
Pretty sure Bimmerlabs does BIN to 0Pa or 0da converstions.
rjahl
BMW Z4 35is
Good question. I thought everyone had access to those tools.
I've been working with the developer, even before he started Bimmerlabs and I might have access to features not available to everyone. At one time the developer was looking to make multiple access levels. one free and one paid. This might have been the paid tool section, just cant remember. As a "collaborator " I was given access to nearly everything and he never implemented the "paid" tiers. He has visions but little time, his daytime job pays way better.
I'll do a little checking but I really don't like to bug the developer much anymore.
In the mean time, you can post the bin file you are looking to create and I can build the Opa file for you.
