Yes you should. It wont work right. Just ask George at split second tuning, he makes the AIC boxes
My brother called Split Sec and asked them. They said this is all they sell. And I guess if you were to purchase the AIC6 from MMP, this is what you would get.
Got mine from MMP, the box was labeled AIC1 but it had a harness for 6 injectors.
Does yours look like this?
http://www.n54tech.com/forums/attachment.php?attachmentid=29038&stc=1&d=1427730269
Mainly the 3 wire connectors.
The box is the same but mine is flash only so the harness is different. I had the main harness and a smaller harness with 4 wires: red, black, yellow, green.
That one looks like it's wired for JB4. The main harness with the 6 injector clips should be the same.
From what I understand they make the AIC (additional injector controller) box in a variety of configurations. Yes you can modify one to fire 6 injectors but most of the vendors sell modified AIC1's. Never heard of a modified AIC4
People telling you this won't work do not understand what is happening when the PI is firing. Is it ideal, not really, will it work, yes. Its simply firing a batch. BOOM it fires all 6 cylinders at the same time, or 1, or 2, or 4, or 8, or 12. We have used the AIC6 on 4 cylinders, just leaving 2 plugs unplugged, and we have seen people run the 4's on 6's, by adding a couple of plugs. I do not prefer to add plugs, but if you already have it, and its modified it will work fine. The controller literally has no idea how many injectors it's firing, it's just lighting them all off in a batch. That's why it's referred to as batch fire...
