Hi guys.
After suggestion from MHD, I tried running stage 2 102 RON map. I am using 100RON fuel, which I believe is testet to an AKI at about 101,7.
MHD says the logs are ok.
I am new, but have read or seen in a video, that corrections above 3 is not good, or on more than 3 cylinders at the same time. I have 5 cylinders with corrections simultatiously, and above 3 degrees of corrections at times.
So would love some input here The gain from running 102 map, is probably not much, so just want to make sure it is safe I was having more or less zero corrections on 98 maps, which makes sence when running 100 fuel.
