Injector(s) dying? Whos got the cheapest legit 12's
colo_evo
159
111
E90 335i MT
Completely stock 07 335i only running a flash. 30k /4 years on index 10 injectors. Issue duplicated on a stage 1 cal and factory cal.
Every cold start the car fires up instantly, but then stumbles and misfires for 3-6 seconds before finally catching itself and cleaning up. Hot starts are better but still does it 10% of the time. There is no long crank so I'm thinking the hpfp is fine. Right now I'm leaning towards the injectors being the culprit.
It won't throw codes, and it won't full on stall, so I'm not sure what bank is having the issue. Logs show ltft and stft are consistent bank to bank. If I decel in gear both o2 sensors max out lean when in dfco. This issue came about after the vehicle sat at the dealership for 2 months waiting on the hvac blower motor replacement.
Before dropping $600+ on new injectors I'd like to confirm they're the culprit. If they are in fact the issue, who's got the best prices on real index 12's?
Thoughts, experiences and suggestions welcome.
Screenshot and log of a relatively good start attached. Sometimes rpms fall to 400 on worse starts. You can see as soon as it goes closed loop fueling the rpm cleans up.
  • 2018-06-10 09_35_41 I8A0S Stg0.csv
I bought mine from FCP for the lifetime warranty. At the time they were priced well but it has gone up significantly.
colo_evo
159
111
E90 335i MT
Wow! Prices jumped significantly... now I really want to be sure it's the injectors before replacing them.
dyezak
1,767
1,518
Plano TX
335is
Yea, I wish I bought a set back when they were $600. Now you are looking at $1500 minimum.
Yeah I think I paid like $800. $600 with a lifetime warranty is a dream. Well assuming they are stopping at Index 12 of course. I don't know if FCP would upgrade you to the latest model...
1,286
781
Someone on e90 let the cat outa the bag about intermotor injectors from Advance. I have yet to see if they commented that they were good. They claim they are new, but... I did find inline where intermotor says they are index 11 "or higher" so it may not be index 12s, but might be worth saving 1100 bucks. They are 137 each, but you can usually find a 20 or 25% off coupon for Advance.
colo_evo
159
111
E90 335i MT
Ordered 3 from advance with 25% off. If they come in and appear okay and index 12 I'll order another 3.
Now, is everybody in agreement my injectors are tired? Any comments on the log or start screenshot?
1,286
781
Did you order them 3 at a time or individually? You only get a max of $50 off I think, so you can save more by doing them individually.
colo_evo
159
111
E90 335i MT
All 3 in one order.
I order a lot from advance, so I know where to find decent deals.
I'll just return them if we decide injectors aren't the issue.
1,286
781
You are Advance auto Ninja with that code. Nice. Definitely let us know if the injectors pan out.
colo_evo
159
111
E90 335i MT
Hopefully they're not junk like a lot of the AA parts are.
I haven't seen any glaring negative reviews, so hopefully they're okay. I'll at least look at the package for these before dropping 1/5 the value of the entire car on the fcp injectors.
1,286
781
I called intermotor a while back because they are listed as new and not refurb and I wanted to confirm. They also apparently come with seals and caps.
Reactions: Xm-n54
1,923
662
I bought the buyauto parts for 784 I originally was going to purchase from rock auto but i posted about the price and went to order and they were out of stock again plus the buyauto parts are 100 percent index 12 and updated for the s63 I also verified with vdo that they were genuine new in box.
1,923
662
I had horrible luck with aa coils had 1 a month fail , out of six only 3 lasted 4 months until i purchased bl coils i will never buy again
colo_evo
159
111
E90 335i MT
Three showed up. They appear to be the continental vdo reman injectors. All have part number a2c9521190280 and the BMW part number scratched out.
1,286
781
I didn't think there were any re-man injectors. Was the index scratched out too?
