Ignition switched 12v in trunk / battery compartment?
veer90
1,000
774
West Nyack, NY
e90 335i 6MT
Looking for an ignition switched 12v source I can tap into around that general area.
Only other one I know of is cigarette lighter fuse in the glove box. Don't want to run wires that long all the way to the back.
2,197
If the OEM system is the standard 10-speaker, the OEM remote turn on is pin 10 in the OEM amp connector. If the OEM system is Logic7, the OEM remote turn on is pin 13 in the rear main connector of the OEM HU/iDrive. So the internet tells me.
That being said it is pretty quick to run a line back to the trunk, yes it is a hassle but easily done.
The real question is what do you need it for ;)
Reactions: veer90
veer90
1,000
774
West Nyack, NY
e90 335i 6MT
My friend wants to try controlling the 2 fuel pumps in my car with an Arduino. This would be the power supply
GreyNBlueE92
266
93
OH
Wouldn't that just be a signal wire to tell the amp to turn on? Maybe BMWs are different, but that's how it is in the aftermarket world.
In short, I dont think that will work...
chrisdfv
270
216
E90 335i
I use the exhaust valve actuator pigtail
Same. I use it as the signal wire for my sub amp. it will come on briefly when you unlock the car, but will shut off again if you don't actually turn on the ignition FYI.
