How have you modified your underbody panels for 1M Replica Bumper
rhodesman
199
120
Maryland
rhodesman.com
2010 BMW E88 N54 135i
I got a 1M replica bumper and I'm having a hard time trying to figure out what I need in terms of the belly trim to make everything fit nice and OEM-ish. Currently I have the OEM 135i underbody panels installed but I'm sure there is something I can either get or a way to modify what I have to make it fit better. Just looking for anything others have done. Pics for reference.
Bnks334
530
343
View attachment 16319 View attachment 16320 View attachment 16321 View attachment 16322
Get a 1M replica bumper splitter and those holes will be filled with brake ducts ;)
rhodesman
199
120
Maryland
rhodesman.com
I would love to but... notice those bits of my vinyl wrap that are curbed at the edges? That's because the transition from my driveway to the street is too steep! I literally have to exit or enter my driveway at a 60*+ angle to not rub. I have plans to have my whole driveway redone to be wider and to decrease the grade and transition, but that's not happening anytime in the near future unfortunetly.
4,340
Did you get the fender liners? On the e9x upgrading to msport required
Bellypan
Fender liners
Brake ducts
Oil cooler duct
Fog lights
miscellaneous items
There is probably not a mesh you can use if the 1m fenders are wider since the bumper is slightly different in shape. I'm unfamiliar with the differences however.
rhodesman
199
120
Maryland
rhodesman.com
I ended up making my own parts out of aluminum. Still test fitting/cutting them to fit better but so far I am quite happy with the results.
1,929
664
Did you start msport or regular cause like double said you should try to see if msport fits it better or m3 underbody
1and1
65
35
Tally, FL
I didn't need any changes, the undertray tucks up into my 1M rep bumper fine.
OE 1M ducts perfectly fit the openings as well- makes for a better, much more aggressive look I think.
