Has anyone ever fit a 28x10x17 on an E82 135i?
suspenceful
10 Second Club
Aug 1, 2017
559
592
75
2015 M3, 2008 135i, 2009 335i
Just as the title states, I'm wondering if anyone has been able to cram a 28x10x17 Hoosier slick in the rear of a 1 series. If so, what where the wheel specs? Any modification required?
I want to run this tire, as many 3 series guys do, but fear it won't fit in the back of the E82 chassis.
According to my calculations, here is what I found out.
The equivalent of a 28x10x17 is a 255/55/17: https://www.summitracing.com/parts/hoo-18157
I am currently running a 275/40/17 MT ET Street radial on a 17x8.5" ET50 wheel. It fit, but required a fender roll. I am lowered on Eibach Pro-Kit springs (~1.5" drop). I also have a 17x9.5" ET54 wheel I could try. I could also try swapping in the stock rear springs to raise it up.
275/40/17 --> 255/55/17 aka 28x10x17: https://www.willtheyfit.com/index.p...2=55&wheel_size=17&wheel_width=8-5&offset2=50
Hypothetically, I don't know if I'd be able to fit a 255/55/17 tire. Much taller, but seemingly a bit more narrow?
suspenceful
10 Second Club
Aug 1, 2017
559
592
75
Here are some photos of E92/E90 running this tire, just to give an idea of what I'm looking to do. I know the E82 chassis has different offsets.
E90 335i
17x8.5" ET40 OZ Alleggerita
E90 335i
17x9.5" ET35 APEX ARC-8
E92 335i
17x8.5" ET50 Style 68 (+12mm spacer = ET38)
56904901_10220008417261874_4958240920882380800_n.jpg?_nc_cat=111&_nc_ht=scontent-ort2-2.jpg
56599896_10219962901804016_4205625001216311296_n.jpg?_nc_cat=100&_nc_ht=scontent-ort2-2.jpg
E92 335i
17x8.5" ET40 Kosei K1
26341
26342
E90 335i
18x4.5" Weld front runners
28x4.5x18 M&H Racemaster skinnies
26343
26344
E92 M3
17x10" APEX ARC-8 ET25
17x4.5" Weld front runners
27.5x5x17 Hoosier skinnies
gmagnus7
174
73
135i N54
Would changing to 335 hubs help I know the 135 is pushed out more right
That would help wheel selection, but I'm more curious if the actual physical dimensions of the 28x10 would physically fit underneath within the wheel well - considering they have a 12" section width.
SJ_1989
368
299
Illinoisssss
2008 E90 335i
My car is the first picture in the second post. That was with a full interior and sport suspension. It BARELY fits and that was with a 3 mm spacer. I have to compress the suspension in order to get the wheel on because it hits that link that connects the chassis to the rear subframe (not sure if 1'er's have it or not). Now it's fully gutted with 328i non-sport springs on it and a 10 mm spacer and it has a lot more clearance. Still an issue with that link though but that's getting modified.
Reactions: suspenceful
